Help!!Run Rough, Smoke From Exhaust And Gauges Went Crazy
Old Aug 15, 2010 | 01:15 PM
slagburger's Avatar
slagburger is on a distinguished road
Angry Help!!Run Rough, Smoke From Exhaust And Gauges Went Crazy
Hi,
I was driving home when the vehicle started to surge for a while then i noticed smoke in the rear view mirror, not sure what color it was dark..then the gauges all went crazy and car coasted to a halt...I lifted hood and it smelt hot although the temp wasnt reading hot and the oil was low to about the fill level..it now doesnt start...Please help...Any suggestions???
Old Aug 15, 2010 | 02:17 PM
Lets start with your vehicle information and we'll go from there.
Old Aug 15, 2010 | 11:12 PM
slagburger's Avatar
Angry Help!!Run Rough,Smoke From Exhaust and Gauges Went Crazy?
Hi, Sorry its a 2001 chevy blazer Lt 4x4
Old Aug 16, 2010 | 06:19 AM
Did the check engine light come on? If so, what were the codes?
Old Aug 16, 2010 | 09:36 AM
slagburger's Avatar
I have just been out and bought a computer diagnostic machine and will try to get the codes from the vehicle....Appreciate the help!!
Old Aug 17, 2010 | 08:26 AM
slagburger's Avatar
tried to read the codes but getting no joy....my dad also has the same car and his plug under the dash is the other way up and his i can read ...my one looks like somebody has looked at this before and put it back the wrong way round....this is going to make it difficult if I cant read the codes huh???
Old Aug 19, 2010 | 11:21 PM
slagburger's Avatar
Hi, What do you think I can do if I cannot retrieve any codes???
Old Aug 19, 2010 | 11:49 PM
Check the CIG fuse. It powers the DLC.
It sounds as though you may have an ignition switch issue given the stall & dash gauges going crazy.
Old Aug 20, 2010 | 12:15 PM
slagburger's Avatar
hi, i have managed to replace the cig fuse and the reader picked up the code P1404 Egr valve stuck open or Circuit Performance??? Now as I said before I do have access to an identicle vehicle to swap stuff over without buying parts and finding out this was wrong....Is the EGR valve easy to swap out?? And again I really do appreciate your help..
Old Aug 20, 2010 | 12:18 PM
Two bolts and an electrical connection is all that need to be removed/disconnected to pull the EGR valve. Take a look at the links below:
EGR Valve Cleaning
P1404 - EGR Valve Circuit Performance Actual Position Greater Than Commanded
