Help!!Run Rough, Smoke From Exhaust And Gauges Went Crazy
Two bolts and an electrical connection is all that need to be removed/disconnected to pull the EGR valve. Take a look at the links below:
EGR Valve Cleaning
P1404 - EGR Valve Circuit Performance Actual Position Greater Than Commanded
EGR Valve Cleaning
You cannot just replace those tubes. They are burning out because the check valve for the AIR (air injection reaction) system is not functioning properly on that side. You need to replace the check valve on the side that burnt or you will just burn out that side again.
I have now replaced the check valve and the plugs ,distributor cap and rotor so far but not the wires and i am still getting a p0300 generic misfire and now a p0135 code coming up which says its an o2 sensor on bank 1 or possably a wiring harness prob which I hope its not because I have just put all that back together or do you think that it is the o2 sensor??? Tomorrow I will replace the wires....It is definately only missing on 1 cylinder....so close to fixing now as long as its not the harness...
Thanks again for your help swartlkk
You can use the wiring diagram found in the link below to test the wiring.
P0135 - HO2S Heater Circuit Bank 1 Sensor 1
P0300 isn't a nice code to have!
P030x - Random/Multiple Cylinder Misfire Detected
Thanks Swartlkk
Hey thanks mate...I found that the misfire was because 2xwires were around the wrong way..I had a guy look at it and he must of put the wires back wrong!!! Now i had cured the misfire i had replaced 1 of the check valves and i thought everything was good untill I got about 30 miles out and the truck started losing power again and blew the other side check valve.....I have also now replaced this and the plastic T valve by the smog pump and have come to the conclusion that upon witnessing the catalitic converter glowing it must be blocked so I will now replace this and hope for the best...and once again thank you for your advice and help!!!
Slagburger
Slagburger
keefer3
11-17-2012 12:46 AM
vortec bowtie
07-07-2012 09:42 AM
XxIRISH63xX
06-09-2011 09:30 AM
BLAZ N A 93
12-30-2009 06:14 AM
