Help, Running way too cold!
Old Jan 11, 2010 | 03:17 PM
Unlimitedsp's Avatar
  1. Disconnect the negative battery cable.
  2. Remove the air inlet duct.
  3. Drain the cooling system to a level below the thermostat.
  4. Remove the thermostat outlet-to-engine retainers (usually either 2 bolts or 1 bolt and 1 stud), then remove outlet from the intake manifold.
  5. Remove the thermostat from the housing, noting the orientation for installation purposes.
To install:
  1. Carefully clean the all traces of the old gasket or sealer from the housing and outlet.
  2. Install the thermostat to the housing, oriented as noted during removal, then position a new gasket (if used).
  3. Place a 1 / 8 in. bead of RTV sealant in the groove on the water outlet sealing surface, then install the outlet while the sealer is still wet.
  4. Install the outlet retainers and tighten to 21 ft. lbs. (28 Nm) for the 4.3L 19-96 models or to 14 ft. lbs. (19 Nm) for the 1997-99 models.
  5. Properly fill the engine cooling system and check for leaks.
  6. Install the air inlet duct.
Attached Thumbnails Help, Running way too cold!-pic1.jpg   Help, Running way too cold!-pic2.jpg   Help, Running way too cold!-pic-3.jpg
Old Jan 13, 2010 | 03:12 PM
CBlazer99's Avatar
CBlazer99 is on a distinguished road
Thank you all! I did the install now my heat works amazingly well, and my car is running much warmer and better! Thanks again!!!
marandajackie
May 7, 2014 08:38 PM
edrock589
Jul 16, 2012 12:02 PM
blazrg
Jun 23, 2012 01:21 PM
tttron
Dec 11, 2010 08:38 PM
RIFLEMAN 308
Jul 31, 2010 03:42 PM
