Help! Water in Gas Tank
Old Feb 28, 2009 | 01:00 PM
Albertablazer's Avatar
Albertablazer is an unknown quantity at this point
Default Help! Water in Gas Tank
Hi there,My son suspects there is water in his gas tank from fuel added yesterday. It is a 99 Blazer. The truck will not turn over and have tried to add one bottle of gas line antifreeze but still won't start. The tank is currently appx. 3/4 full and am thinking we need to drain? Any suggestions on how to do this or to remedy this problem? Any help is appreciated. Thanks!
Old Feb 28, 2009 | 01:39 PM
rriddle3's Avatar
Default RE: Help! Water in Gas Tank
Did the problem only show after he put the gas in and was it from a station he does not normally use? If you are confident it has water in the tank, I'm afraid only dropping and draining, followed by a 'gas dryer' additive treatment will remove it. For help with the dropping, look below in 'Related Threads' or use 'search' for 'gas tank removal', 'drop tank', etc.
Old Feb 28, 2009 | 01:46 PM
Hi, thanks for your reply. Yes, the problem occurred after refueling, however gas used was from a sliptank, not from normal gas station,so am unsure amount of water. We are now assuming that there was water mixed in. Trying to find acost-effective solution and and wondering if we are able to drain fuel tank ourselves?
Old Feb 28, 2009 | 02:55 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
If it's a 4dr blazer it will be a major pain to drop the tank. Also you said the engine won't turn over, I assume you meant that the engine will turn over but it won't fire..correct?
Have you checked to see if the fuel pump relay is blown? Look in the glove box and pull the fuel pump relay and switch the horn relay to see if your pump is working.
Old Feb 28, 2009 | 03:58 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Mixing in straight alcohol will help to mix with the water and burn off if there's not much in there.
AnjelDust
Nov 3, 2014 09:39 AM
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
