Here is a fun one for you experts!
Old Mar 25, 2017 | 12:16 PM
LoneWolf71's Avatar
LoneWolf71 is on a distinguished road
Exclamation Here is a fun one for you experts!
So, I put a new radiator, belt, and alternator, as well as oil change last night. Once it was all done I filled the radiator with distilled water and a flush and am going to run it for a few hundred miles just to clear out any residual dex-cool that was left from my last backflush. This is really irrelevant to the issue at hand. So once everything was put back together, I fired her up and the battery light was coming on and off. Checked the belt to make sure it was not slipping, it is good and tight and spinning fine. Checked alternator wires and everything seems ok. This was not happening with my old alternator. So I took it to advanced and they ran a test on the battery, and the alternator and both passed with flying colors, but the battery light is still going on and off. Any ideas as to why this is? I have a feeling it is the alternator, bad out of the box but the test show otherwise. Cranking out 14.7+ on the test. Battery is Brand spanking new and tested good. What say you? Thanks!
Old Mar 25, 2017 | 01:34 PM
newguy's Avatar
I'm betting alt. Also. Tell them you want to swap it
Old Mar 25, 2017 | 03:08 PM
rexmburns's Avatar
Super Moderator
Your certain all wire connections are tight?
Old Mar 26, 2017 | 12:44 PM
LoneWolf71's Avatar
I am certain, I am pretty sure its the alt. Even though it tests out fine, there must be something going on. I know it is supposed to send back 5v to the pcm, maybe it is not doing that?
Old Mar 27, 2017 | 09:46 AM
Tajohns34's Avatar
Take the alternator back and have it tested. It sounds like it is bad.
Old Mar 27, 2017 | 12:37 PM
newguy's Avatar
He did already, they said it was good. But I differ
Old Mar 27, 2017 | 02:37 PM
rexmburns's Avatar
Super Moderator
I'd say alt as well then if everything is tight and the belt isn't slipping. What was the reason for the new alt? Do you still have the old one?
Old Mar 27, 2017 | 02:39 PM
LoneWolf71's Avatar
Yes, I do believe it's a "Bad out of the box" alt. I think I will buy a Bosch anyway. I can install my old one, nothing was wrong with it, it just has some age on it and thought what the heck, So I will install it back on and wait for the Bosch to get here.
Old Mar 30, 2017 | 08:11 AM
Tajohns34's Avatar
I have seen bad alternators test good before. My sister had a Nissan Sentra that would not charge only at high rpms, the stores only test at low RPM.
redneck44244
May 23, 2012 12:52 AM
El Diablo793
Lifting Tech
Sep 10, 2011 01:21 AM
amnotblonde
Jun 10, 2011 11:15 AM
kiwiblazer
Feb 4, 2011 11:59 PM
2kSnakeEater
May 11, 2006 11:17 PM
