Hesitation I never had before
Old Nov 12, 2009 | 05:12 PM
pshtr's Avatar
pshtr is on a distinguished road
Default Hesitation I never had before
I have a 96 blazer, 4x4, with 4.3 vortec. About a month ago I replaced the fuel pressure regulator because of hard starting and rough idle, the mechanic said that's what it was. Ran fine for 4 days then died on me while driving, sat for a month and then I had the fuel pump replaced with a Delphi. Got it back and ever since, I have a hesitation taking off from a stop, under driving conditions it seems fine. I notice a vacuum leak coming from the brake booster hose to the top of my intake manifold. What is that part that fits into the top of the intake manifold and could this be the problem? That is where it is leaking from, around the base where it fits into the intake manifold cover. I will try to fix it tomorrow but I don't even know what that is and just wanted to know. Thanks
Old Nov 14, 2009 | 12:16 PM
That is just a plastic 1/4 turn fitting with an o-ring seal. It is possible that the o-ring has been cut somehow... It is likely that the mechanic who did the FPR replacement messed it up.
Old Nov 16, 2009 | 12:08 PM
pshtr's Avatar
That is exactly what happened. Thanks
Old Nov 16, 2009 | 12:13 PM
Did you replace the o-ring? Did it cure your hesitation issue?
I am just trying to get the full resolution so that anyone who may be experiencing the same problem later on may find this thread useful.
Old Nov 16, 2009 | 03:20 PM
pshtr's Avatar
When I got under the hood I could hear the hissing and went straight to that elbow fitting. It looks like the oring may have been stretched out or flipped and the elbow pinched the oring causing the elbow to not seat properly from what I saw. I did replace the oring, $1.13 from dealer. The hesitation went away immediately but now I have the dreaded P0440. Came out of nowhere, giving me other stuff to check.
Old Nov 16, 2009 | 03:51 PM
Reset the code and see if it comes back.
In the mean time, read up on the code:
P0440 - Evaporative Emission Control System
Old Nov 16, 2009 | 04:33 PM
pshtr's Avatar
Will do. I do smell some fuel under truck by tank but I just had pump replaced, I hope they didn't break a hose or valve. But resetting the code will be my first recourse for sure. Thanks and if I find anything useful I will post it.
Old Nov 30, 2009 | 04:51 PM
pshtr's Avatar
96 blazer, 4x4, with 4.3 vortec with new fuel pump and P0400 code. Well, cleared the code and it stayed off for about a week. It seems to have come on around the same time as before, about a 1/16 less than half of a tank. I haven't noticed any broken lines under there or at evap canister. Is the purge valve on the fuel pump towards the front of the tank? If anyone can narrow this down for me a bit I'd appreciate the help. Thanks
C.Myers601
Apr 18, 2013 03:08 PM
97cherryblazer
May 25, 2012 01:13 PM
liquidprozak
Feb 27, 2012 10:58 AM
Suncrest Sniper
Sep 15, 2011 12:34 PM
93 s10 justin
Lifting Tech
Mar 15, 2010 06:13 PM
