new to blazers, never seen this before!!!
Old Mar 13, 2010 | 09:09 PM
93 s10 justin's Avatar
93 s10 justin is on a distinguished road
Default new to blazers, never seen this before!!!
so i am new to owning a blazer and every other 4wd i have seen has had the rear leaf springs mounted above the rear axel, mine are below the axel and im not sure why, do blazers come like this??? if so why? and what should i do to lift it, i have no idea how to approch this accept to move the springs above the axel and get a slightly bigger lift on the front than on the rear, any help would be much appreciated
its a 93 s10 blazer tahoe lt edition btw
Old Mar 13, 2010 | 10:42 PM
abig84's Avatar
you answered your own question. or you can just buy lift springs. makes it easy for the guys who want to lower their trucks they just put a block in the back. on my 93 i put the axle under the spring for a little bit of lift. but thats the easy part. the more involved costly lift comes in lifting the front.
i really dont know why they put it on top of the spring
Old Mar 13, 2010 | 10:55 PM
LuvMyTJ's Avatar
This is very common to have the axle over the spring pack. It makes for better on road manners. In the off road world many people do whats known as a SOA Lift, or Spring Over Axle Lift. It will give you 2-3 inches of new found height! It usually isn't to hard to do, and there may be kits specific to the Blazer you can buy. It is mainly just replacing the U bolts and making sure/replacing the brake lines and verify that the steering links are clear and have a full range of function, both compressed and flexed.
Old Mar 14, 2010 | 09:19 AM
tony991's Avatar
tony991 is on a distinguished road
Actually a SOA lift gives you about 5-5.5" of lift. You have to add up the thickness of the axle and the leaf spring pack.
Old Mar 14, 2010 | 10:01 AM
Rottidog's Avatar
there are SOA kits out there that include components for the front as well as brackets for the rear leafs
<edit> always replace, never re-use U-bolts
Old Mar 15, 2010 | 06:13 PM
LuvMyTJ's Avatar
Yeah, your right... 5'ish inches easy.
CAB
Jan 6, 2021 10:04 PM
Dobe Rottie Gang
Aug 30, 2013 11:14 AM
C.Myers601
Apr 18, 2013 03:08 PM
ZaBlazer99
Jan 19, 2013 08:20 AM
ihatefordz
50
May 12, 2012 05:06 PM
