Hesitation Upon Starting
Old Apr 9, 2018 | 03:51 PM
David12's Avatar
David12 is on a distinguished road
Originally Posted by Lesmyer
I'm with Perumotors on the possibility of a lazy fuel pump not being all the way up to pressure after one 2 second pulse, requiring several key cycles to get it to run correctly. Maybe even a plugged fuel filter.
Thank you, I will change the fuel filter first and will check back again with you guys.
Old Feb 14, 2021 | 01:17 PM
gardoe61's Avatar
gardoe61 is on a distinguished road
i have a 2004 4 door 4 WD 4.3 and is doing what you said,it will start fine most of time from cold,drive around to couple places then no fuel pressure when crank-i checked with gauge one time in driveway when wouldn't start-so i found crank couple seconds turn of for about ten seconds try again so far will start after few attemps.It is a fuel pump from advance,second one,people say go with better brand,i think that is good idea.Runs fine after starts,may swap with horn relay just to see if any difference.
Old Feb 14, 2021 | 01:24 PM
gardoe61's Avatar
my 2004 blazer seems to have lazy fuel pump,sometimes won't start up after drikve somewhere.RUNS FINE AFTER STARTS.
blazerontwenties
Oct 9, 2013 08:00 PM
sdumontjr5
May 14, 2012 04:32 PM
jakeclope
Dec 18, 2009 10:19 PM
jhuseman
Nov 13, 2006 09:30 PM
