Hi I am new to the forum but I have questions
Old May 4, 2011 | 01:38 PM
bryanhodki's Avatar
bryanhodki is on a distinguished road
Default Hi I am new to the forum but I have questions
I have a 99 that has the 4.3 and it is giving me a p0300 engine code which I believe is random or multiple cylinder misfires. I have changed the cap,rotor,wires,plugs, and egr with no change in the engine performance. I put a test gauge on the fuel pressure test port and I was getting a rapid fluctuation between 65 and 75 psi with the engine running. I did see that some guys had problems with distributor gears I guess I can check the distributor next, If someone thinks that might fix the problem. Any insight on this would be great!
Thanks
Old May 4, 2011 | 01:44 PM
jackdough's Avatar
jackdough is an unknown quantity at this point
possibly coil? injectors? fuel pressure regulator? could be a lot of things. thats all i can think of right now. try searching p0300 im sure you will find lots of problems/solutions
Old May 4, 2011 | 02:40 PM
bryanhodki's Avatar
Yeah! That is what I was afraid of, I guess I have to just start changing out more parts it sounds like until I hit the right one that makes the problem go away. Thanks for the heads up!
Old May 4, 2011 | 04:24 PM
jackdough's Avatar
total wrong way to go about it. you will end up spending ton of money you didnt need too. do your research and whatever part you suspect there will almost always be a way to test it and make sure your not pissing money away. search function can be your best friend. good luck
Old May 4, 2011 | 06:16 PM
rriddle3's Avatar
The dreaded P0300 CAUTION LONG POST
P030x Explained (x=0,1,2,3,4,5,6)
There is sooooo much information on this site, using the 'search' function makes things so much easier.
Old May 5, 2011 | 12:33 AM
bryanhodki's Avatar
Alright some trouble shooting info. Thanks for the attachments!!! I will let you guys know what I find. Thanks again
MJKH84
13
Jul 3, 2023 08:46 AM
88k5high
Dec 13, 2011 07:59 AM
tfcman
Sep 9, 2011 01:47 PM
rlepera
Oct 15, 2009 04:09 PM
dmoore1200
Mar 15, 2005 09:52 PM
