High fuel trims, and drivability problems
#21
Have 2 new codes now. P0171 and P0174.
I took readings for the sensors you listed iat idle, and the the rpm's you specified. I took video so you can see them in real time. Was too hard hold the gas, read the scanner, and write everything down at once. I'm uploading them now, and will post in a few minutes.
#26
Looks like no vacuum leak
Looks like your MAF may be severely under reporting at 1700 rpm. You read 11g/s at 1700, I read 25 g/s and Les Myers (in an old thread) read 35. That could be it. Swap with a known good MAF if you have one or if not turn the truck off, unplug the MAF and start it up and see what your fuel trims are doing. Under those circumstances, the truck will determine the theoretical fuel delivery using other sensors in speed density mode.
George
George
#27
With my other maf the reading went up to 1.7 lb/min at 1700, and .66 at idle on my 1st test.
While warming it up I found that there is a nut missing from one of the exhaust studs at the y pipe on the driver side.
I also took apart the old maf as well, so I could clean it better, and the rounded side of the bars were FILTHY.
