high idle speed on start
Old Feb 20, 2012 | 01:38 PM
berniescout's Avatar
berniescout is an unknown quantity at this point
Default high idle speed on start
I have just noticed on start the idle jumps to about 1000-1500 rpm, then slowly drops to normal. I inspected the vac lines thinking might be a leak. Replaced 2 short peices near the vac canister mounted on the hood, they were badly powering. no fluids in the lines.
about 3 weeks ago I replaced the transfer vac switch. maybe tomorrow i will pull the vac hose off of it and see if any fluid is being sucked in.
any thoughts
97 blazer 3 button 4x4 automatic.
tnx
bernie
Old Feb 20, 2012 | 02:26 PM
Longer02's Avatar
Longer02 is an unknown quantity at this point
That is normal.
Old Feb 20, 2012 | 07:51 PM
don't think this is normal. never done this before. tomorrow will hook up scanner. no check engine light.
tnx,
bernie
Old Feb 20, 2012 | 09:44 PM
war00's Avatar
war00 is on a distinguished road
could be your iac motor, but on cold start up mine idles at 1000rpm than as it heats up the idle comes down to 500rpms. what are you driving?
Old Feb 20, 2012 | 10:06 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Mine idles at about 1300 when i start it up cold.. Sounds about normal to me. It only does it in the winter tho. I wouldnt worry to much about it, unless it starts to idle higher than 1500
Old Feb 20, 2012 | 10:21 PM
ok, but I have never noticed this before. Have had the blazer 8+ years, this is the first time, the vehicle is stock 97, except for the kn air filter. I will keep an eye on it.
bernie
Old Feb 20, 2012 | 10:54 PM
pettyfog's Avatar
Hmmm... ever clean the MAF? PCM's often up the idle when sensors dont quite add up.
Old Feb 21, 2012 | 04:48 PM
step66's Avatar
Hey!... Longer02,97cherryblazer & pettyfog are all correct-this IS a normal situation(I never liked it much either at sub-zero temps but..) Do look at the MAF-even the slightest restriction there will cause issues.If this occurs when fully warmed up I would be more concerned about vacuum leaks then. No CEL? Then the system is doing what it is supposed to do-upon cold starts getting oil to the cam & valvetrain as fast as possible! step66
mcdevin1973
Oct 5, 2014 02:52 PM
B3NDER
Feb 24, 2014 07:56 PM
Kevin Gore
Dec 13, 2013 09:35 PM
DaveHearne
Apr 30, 2010 11:27 PM
Kraked Jack
Oct 12, 2008 09:59 AM
