Is his LIM install guide correct?
In the sticky helpful posts section is a link for replacing the lower intake manifold for a 99 GMC 4.3L. In the summary section is says to torque the bolts to 35 ft lbs. All the other guides and I saw and the one I used says 132 inch lbs which I thought equals 11 ft lbs. Is the GMC 4.3L different? Just having one of those "Did I screw up" moments.
http://www.handymanlyness.com/archiv..._99_Jimmy.html
Installation:
Installation:
- Set new gaskets in place and apply silicone to flat areas on front and rear of engine block.
- Apply thread locking compound to manifold bolts.
- Install manifold and tighten bolts to 35 ft-lbs, in proper sequence.
- Install distributor.
- Install upper intake manifold.
If you don't snap off a bolt, you will most certainly over compress the gasket, compromising its integrity.
Bolbol
05-23-2015 09:12 AM
Joey1986Z
06-23-2014 11:09 AM
