Hood hinge help
Old Jun 21, 2011 | 01:30 AM
teddybeer21's Avatar
teddybeer21 is an unknown quantity at this point
Default Hood hinge help
I purchased the washers from the dearlership. My question is it came with two washers and are they both for one hinge or does one washer for each hinge?
Old Jun 21, 2011 | 08:39 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Not sure if this answers your question but here is my experience. Over the past few months, I noticed a thumping noise from the front end when I went over railroad tracks or speed bumps. I thought it was the front suspension (balljoints, etc.), so I took it to the dealer to replace anything worn out. They said the suspension was tight. The problem was loose hood hinges. They installed 2 washers in the hinges and that fixed the problem. So 1 washer per hinge was what they installed.
2 washers
Part # 12383460 $4.38 each
2002 4 Door 2wheel drive Blazer
Hope this helps.
Old Jun 21, 2011 | 10:12 AM
Yeah that helps thanks. I have the washers just wanted to make sure it was for both hinges
Old Jun 21, 2011 | 10:20 AM
Yep, one on each hinge bolt. Put them between the hinge and the nut with the raised center towards the nut. This is a belleville washer which acts like a spring to put added tension on the joint without worry of relaxation over time.
I have seen some hinges where the owners have put regular washers which caused the hinge to wear and loosen up again. On those, I have had to use two belleville washers.
Old Jun 21, 2011 | 03:04 PM
Thanks for the help. Installed them and no more "clunk"
blueblazerguy
Jan 7, 2011 07:59 PM
blazin8556
Jun 10, 2010 07:23 PM
jsmz
Oct 17, 2008 01:37 AM
Scream And Fly
Aug 26, 2006 12:25 AM
