Hood Latch adjustment ?
Is there any adjust ment to the hood latch......
I have a 2000 S10 pickup and i am replacing the dented
hood with one from a 2001 S10 Blazer...............
Should be a simply swap.. but my hood latch isnt lining up
Any adjustments to the latch.... or ... some other place ?
any help is appreciated ~ ~ Dw...............
RE: Hood Latch adjustment ?
You should be able to loosen the bolts and move it up/down to line everything up. You will also have to move the outer bump stops either up or down to line the hood up flush with the fenders. Everything should be the same between the two vehicles.
thanks ~ ~
edit ~ ~ ~>
in new post~>
edit ~ ~ ~>
in new post~>
ThanksKyle
I found the left to right adjustment.. by taking the whole bracket off
and turning it over and loosened them nuts.. and got the hood to close and re
open better ~ ~ Darrell ~
Great! Glad you got it all fixed up!!
Yup.......... never needed to adjust the hood b4........ ! Darrell ~
blazer4x4
09-12-2007 11:59 AM
