Hot brake rotors
Old Aug 18, 2017 | 02:17 PM
Willyclay's Avatar
Willyclay is on a distinguished road
Default Hot brake rotors
New member and old geezer with 98 Blazer, four-door, 2WD, LS model with 124K+ miles. Independent shop replaced R.R. caliper that was sticking plus new pads in both rears. Told me they test drove it after repairs and realized the parking brakes were on. When I picked it up, the parking brakes seemed ok. About 30 days later, the R.R. caliper was sticking again and was replaced plus a new hose. After a few thousand miles, I realized the parking brakes were not holding well and decided to replace them myself. I did and found the adjusters were both at "zero" but the cable had been tightened significantly. Had to back off the cable a bunch to get new parking brake linings not to drag. Put it all back together and drove it less than 100 miles and found the L.R caliper was sticking. Replaced that and the hose myself and everything seemed right; minimal drag, even braking, good pedal, no leaks. no noise. My concern is the L.R. rotor temperature is consistently 50-60 degrees hotter than the R.R. rotor according to my Harbor Freight Laser thermometer! Do I still have a problem with brakes or is that just the way these old Blazers are?
Old Aug 18, 2017 | 04:15 PM
newguy's Avatar
Could be old rubber brake lines. They will imploded and not release
Old Aug 18, 2017 | 04:44 PM
GeorgeLG's Avatar
Sometimes a caliper rebuild can malfunction. Either the piston won't release or the pins and slider gets hung up.
+1 on the rubber hose.
George
Old Aug 18, 2017 | 05:13 PM
Willyclay's Avatar
L.R. has new hose but a reman caliper. Prefer new mechanical parts but went with the reman because it was the only one at my local parts store.
Old Aug 18, 2017 | 07:19 PM
GeorgeLG's Avatar
I use reman calipers also but I am careful with the brand and check operation at the install to be certain that they release correctly and the slide pins are slick etc.
George
Old Oct 11, 2017 | 07:58 PM
Willyclay's Avatar
UPDATE: After 20 miles of around-town driving today, RR rotor was 135F but LR rotor was 235F. Considering a complete brake fluid flush. Comments?
Old Oct 11, 2017 | 08:19 PM
LannyL81's Avatar
What condition are the rear rotors in? Fluid flush is always a good thing to do if not been done for awhile.
Check those sliders and be sure to use the proper grease.
Old Oct 11, 2017 | 09:24 PM
Willyclay's Avatar
Thanks for the reply. Rotors are excellent by my old geezer eyes. Slider seemed good before installing the reman caliper on the LR but will check it again and report back.
10-78 edac
Apr 24, 2012 09:24 AM
Mandrwj
Apr 10, 2011 07:32 PM
vze4yrte
Aug 30, 2010 09:08 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
leritz
Sep 6, 2006 03:04 PM
