How do I check the fault codes on a 97 Blazer
Old Mar 15, 2010 | 01:39 PM
jairriv's Avatar
jairriv is on a distinguished road
Default How do I check the fault codes on a 97 Blazer
Please i need information over How do I check the fault codes on a 97 Blazer
Old Mar 15, 2010 | 01:54 PM
Schrade's Avatar
Schrade is on a distinguished road
Some DTCs can be had by jumping proper pins on the ALDL interface under the dash (I got a pic in another thread of that jump). Others you'll have to go to Advance / Zone, and get a scan done. And some will not read even with their scanners.
After you get them, head for a local mechanic, and see if they'll printout for you the FACTORY diagnostic procedure. Might have to pay them a few bucks...
Old Mar 15, 2010 | 02:03 PM
Anything 96 and later will be fully OBD2 compliant which means that a scan tool is required to read the codes. There is no paper clip trick that can be done to these trucks to read the PCM codes, but that trick does work for 4wd system codes on the OP's truck if so equiped.
Once you get the codes, post back up and we'll get you covered. There are many code sheets already posted in the Tech Article (DIY) section.
Old Mar 15, 2010 | 02:06 PM
Schrade's Avatar
Like my sig says:
Never got a nickel for wrenchin', so I know nuthin'
BlazinIowa
Feb 4, 2011 01:50 PM
mdemers2006
May 25, 2010 02:49 AM
LittleT
Oct 23, 2007 01:02 PM
drperry
Jul 4, 2007 04:25 AM
dashyman
Mar 7, 2006 01:12 AM
