How do I get to the vacuum canister in the fender?
Old Sep 26, 2010 | 07:11 PM
Old Man 2's Avatar
Old Man 2 is on a distinguished road
Question How do I get to the vacuum canister in the fender?
I have a 1999 blazer 4x4 which lost the brake booster because a vacuum line broke. All of the vacuum lines need to be replaced. My question is do I have to remove the fender to get to the vacuum canister?
Old Sep 26, 2010 | 07:53 PM
MLRS327's Avatar
MLRS327 is on a distinguished road
Oh, man. I just had this problem yesterday. My vacuum line for mode door had come loose from it and I started to pull the (brake cylinder?) to push it forward out of the way. Then the mounting bracket was in the way, removed it and the mounting bracket retaining assembly that I did not know was there fell into the fender. Got it all squared away, but a PITA. Anyway, the nipple for that canister line comes into the engine right below/behind the brake cylinder. Dont have to remove anything. Just feel for it. Are you replacing the canister in the fender?
Old Sep 26, 2010 | 08:01 PM
R134A's Avatar
R134A is on a distinguished road
No you do not have to remove the fender you have to move some stuff out of the way but you do not have to remove the fender.
Old Sep 27, 2010 | 10:35 AM
Old Man 2's Avatar
Default Old man 2
Thanks for the help.
I,m not replacing the cannister only the hose.
Old Dec 4, 2010 | 02:35 AM
jackrabbit26's Avatar
jackrabbit26 is on a distinguished road
Actually, you don't have to move anything. The hose which runs to the vacuum resevoir sits on a nipple which pokes through into the engine compartment right under the power brake assembly mounting bracket. You can't see it very well, but you can feel it and access it well enough to attach the hose by hand. If it is still attached, follow the 5/32 hose from the 'T' valve to the wall of the engine compartment. This is it. The other 5/32 hose runs to your cabin air diverter/actuator alongside the wiring harness to your Defrost controls...
Old Dec 4, 2010 | 02:55 PM
jim109's Avatar
jim109 is on a distinguished road
What if there is no nipple? I can only feel a hole.
Toby Hanson
Jul 7, 2014 08:21 AM
turple27
Dec 28, 2012 06:34 PM
Cjlooper
Nov 16, 2010 10:03 PM
leeclark
Jun 5, 2010 01:16 AM
andrew_as
Jul 18, 2009 02:08 PM
