How do I replace door locks with new ones
So my Jimmy got broken into the other night (and im still %&*#@ing pissed) but long story short they got a spare key to it now. I am going to replace the key locks on both doors (its a 2dr) but am wondering how hard this will be? I see the new cylinder locks with two keys costs around 50 bucks.
Any idea whats steps i take to do this task? thx in advance for help!
i havent had to do blazer handles before, but since they are similar to full size chev's, it should only be 2 bolts. one on the outside of the door and the other will be on the inside behind the panel. there should be an access hole and you might need a wobble extension.
http://members.modernvespa.net/fluff...gp6257_211.jpg
but other than that, it should be fairly simple. just dont bend the rods that attach the door handle to the locking mechanism. it will be a pain to bend them back to the right spot. getting the cylinder out should be simple. there is either a clip or a little tab that you might have to push in to get the cylinder out. then just repeat backwards to install.
good luck.
good luck.
Alright thanks! I bought the lock kit from oreillys last night for only 17 bucks also! Much better than the price I found online at autopartswatehouse.com of 46.
I will let you guys know how it goes and try to take some pics for future reference for people
I have a 1998 GMC Jimmy and the driver's side door lock seems to need replacing. Basically, whenever I turn the key, the lock itself is stuck. Only in warm weather does it turn, but in colder weather, forget it. I have to turn it, then turn back, then turn it again, then turn back, then turn it again, then turn back, until finally it will release, and sometimes I just have to open the passenger door and unlock it from the inside.
To replace it, do I have to do the same as for removing the door handle itself, only instead of replacing the door handle, I just put a new lock in? Or can the door handle remain in place and the lock be taken out?
ussexplorer
May 11, 2011 09:04 PM
Benedict1337
Aug 10, 2010 08:41 PM
flowmasta
Jul 26, 2006 01:16 AM
