How do you remove the fuel pump out of the tank?
I was just wondering how to remove the thing that holds the pump in the tank off of the tank. I have the tank dropped ~5" and disconected, I just need to know how to get it out. Thanks.
The locking ring needs to be turned to unlock & release the pump. This is typically done with a brass punch & a screw driver. If fuel is present on the exterior of the tank, it is very important to use a brass or otherwise non-sparking material for this task.
Can I get one from autozone do you think?
A brass punch? Don't know exactly, but probably.
Ok thanks.
You're probably going to need more than 5" to get the pump out, I pulled my tank completely out to do it. But I could be wrong, depends on the pump style (being a 95 it's probably different than mine)
Yeah it came out easy. Now I have a new problem. The new pump wont turn on.
Did the new pump come with a new, 4-flat connector (4 pins all in a line) instead of the factory 2x2 connector?
No, the connector in the tank has 2 pins. And the connection on the outside of the tank has 3. The pump didn't come with one. I wasn't able to get an oem brand, so mabey that had something to do with it. They only had an airtex pump, and scince I need to get home on friday, I didn't really have much choice.
can always swap it out with an oem one when you get time right ? =P
