How to drain the fluid from the front diff?
Old Aug 22, 2007 | 06:14 PM
johnny97's Avatar
johnny97 is an unknown quantity at this point
Default How to drain the fluid from the front diff?
I have a 97 Blazer4x4. I did not find a drain plug for the front gear box. Any Suggestions?
Old Aug 22, 2007 | 08:31 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: How to drain the fluid from the front diff?
For the front diff, there is a drain plug near the bottom of the main housing near the split in the case. HTH
Old Aug 22, 2007 | 09:35 PM
I don't think that the earlier front diffs had a drain. If this is the case, then you'll need to get a transfer pump (hand powered are available for not a lot of $$$) and suck out all of the fluid out of the fill hole.
Old Aug 22, 2007 | 09:58 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Agreed with swartlkk, I have a 98 and no drain plug that I could see so I just got a hand pump for like less than $10. It worked great and was good for removing the fluid from the front and rear diff and then adding the new stuff, it just screwed onto the top of the quart bottles.
Old Aug 23, 2007 | 10:43 AM
johnny97's Avatar
I didnt find a drain plug, so i guess i am going to buy a hand pump thanks guys
Old Aug 23, 2007 | 11:33 PM
Chevy Lover's Avatar
I think the drain plug may look like one of the housing bolts on the '98 model.
[IMG]local://upfiles/2910/BFF64D26D3204DCA8DA01516853833A6.gif[/IMG]
Old Aug 27, 2007 | 02:55 PM
drperry's Avatar
Yep, it looks exactly like a housing bolt, except it's got the little tell-tale plastic ring under the head of the bolt... If there is one... My Haynes manual tells me the front diff has no drain plug at all, even though mine is there, lol.
BrinkDiamond
Mar 2, 2014 03:50 PM
BigBlue21
Jul 28, 2012 12:40 AM
ComputerNerdBD
Jan 14, 2012 12:07 PM
hotrodln
May 3, 2010 08:25 AM
Brianator99
Aug 30, 2009 06:18 PM
