How to get that dadgum tilt wheel lever out??
Old Apr 1, 2006 | 07:08 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Default How to get that dadgum tilt wheel lever out??
I've been stumped twice on this - with a 1999 Blazer and currently with a 1997 Blazer.
I need to pull the steering column to replace the ig\nition switch - and in order to get the upper and lower shrouds off the column, I need to remove the tilt wheel lever. The FSM shows that it pulls out - but mine doesn't. Is there a secret release, or some other part which must be removed first? I'm stopped until I get a way to remove that tilt wheel lever.
Al in Colorado
Old Apr 1, 2006 | 07:37 PM
pilgrim's Avatar
Default RE: How to get that dadgum tilt wheel lever out??
it's a miracle! I finally got so PO'd at that tilt lever that I removed the screws holding the shroud together, which let me get a finger behind the large rectangular part of the lever. I pulled HARD and it finally popped out.
Maybe GM actually knew what they were writing in that part of the FSM.
Old Apr 2, 2006 | 04:29 AM
Welcome!
Glad you got it figured out.
The FSMs are one of the best references you can have and a vast majority of the time, the process spelled out in the FSM is the easiest way to go about that particular repair.
Old Apr 2, 2006 | 05:46 PM
pilgrim's Avatar
I agree! I've found that Ebay is a pretty darn good place to get the FSM. I have one for every one of the five vehicles we drive on a regular basis. What drives me nuts in the GM manuals is all the cross-referencing between sections. To remove one part, you may have to look through five different sections in two different manuals. Great fun.
Old Dec 16, 2009 | 09:08 AM
99Blazer99's Avatar
99Blazer99 is on a distinguished road
I read in the DIY that wolfpak did for the ignition switch, that he uses a small screw driver. I am not quite sure where he used the screw driver to pry... should it just pull out?
Appreciate the help
Old Dec 16, 2009 | 09:18 AM
Yes, it should just pull out. That is what the FSM states and what pilgrim states above.
phantom
Jun 5, 2009 05:23 PM
DLFrederick
Mar 29, 2008 10:47 AM
thevair65
May 16, 2007 07:34 PM
ghostrider2k
Feb 7, 2007 12:09 AM
kakn
Dec 23, 2006 02:21 AM
