how many CCA is your battery???
ORIGINAL: drperry
Unless you see -4 or colder on a regular basis, you won't need anything more than the stock battery...
Yeah, you should only be concerned if you get negative temperatures and if you're gonna deal with negative temperatures, also get an engine block heater. Cost is basically the same as a battery upgrade (up here at least). I had the stock battery for half of the winter last year and itwas good with the coldest temps in the single digits.
My truck comes with a 690CCA battery in it, thanks to AC Delco...
On a side note, taking off that annoying battery sleeve makes installation of the battery 10 times easier...
It feels and looks like it frees up 1/4 inch or so of space around the battery...
I seem to be having problems with my Optima red top, doesn't seem to like lasting through a weekend. Apparently it has a 3 year warrenty so I shall try my luck at getting a replacement at Autozone.
ExplicitYourSelf
11-12-2009 09:52 PM
