How many wires into alternator?
Old Jan 8, 2010 | 11:38 AM
rraasch04's Avatar
rraasch04 is on a distinguished road
Default How many wires into alternator?
OK, so on Dec 28th I replaced the alternator because anytime it would rev above 2500 the volts would drop down to 9. This fixed the issue, however, last night it dropped down to 9 and stayed there for 1/2 hour drive home. Of course, after a while the battery light came on. When I first start it, it runs at just a hair above 14 volts, but after 5 minutes of idleing or starting to drive it drops back down to 9 and doesn't return. I took the alternator and battery in and they tested good.
Now, when putting in the new one I noticed there are two wires on the positive post of the alternator. I would think that there should only be one that goes to the battery, correct? Also, the plugin for the voltage regulator only has 1 wire in it. Is that correct?
Thanks, otherwise any other ideas what could be cause this?
Old Jan 8, 2010 | 11:44 AM
nj4x4blaze's Avatar
I have to look at my battery. But I think one wire goes to the alternator the other goes to the fuse box that has the DRL relay and ect.
Old Jan 8, 2010 | 12:22 PM
Here are the starting and charging diagrams for your year. There are two fusible links, one that runs between the battery and the alternator and another that runs from the alternator to the starter relay.
I am not sure if all of these each have a different terminal at the alternator or not.
Old Jan 8, 2010 | 12:35 PM
rraasch04's Avatar
Thanks guys, I was really hoping for "NO there should only be one!" dang... it's gonna be a long night.
scphill34
Mar 31, 2013 09:41 PM
Mrthelaxer
Mar 20, 2013 08:00 PM
Blazer51
13
Jul 14, 2012 06:03 PM
rogggg1020
Sep 24, 2008 06:53 AM
wostibot
Oct 20, 2006 01:08 AM
