How to remove rust in cylinder
Old Sep 20, 2011 | 05:12 PM
jimnva's Avatar
jimnva is on a distinguished road
Default How to remove rust in cylinder
Head cracked on my 95 4.3 and had heads removed and reworked. It took awhile and now surface rust is in the back 2 cylinders.
What would be the best way to remove it without scoring the cylinder walls?
Liquid rust remover has not removed it all. It is pretty heavy right at the top where the piston and cylinder meet.
Thanks in advance for any suggestions.
Old Sep 21, 2011 | 09:47 AM
dobyken's Avatar
dobyken is on a distinguished road
I wouldn't worry too much about a little surface rust...it will clean itself. You can take a clean rag with a little engine oil on it an wipe off most of it. You should, however, check your cylinders for wear with an inside caliper. It doesn't look like you planned a rebuild but it's something you might as well check whiile the heads are off.
Old Sep 21, 2011 | 06:02 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
do you have all the pistons out? then just do a quick honing job and the will be cleaned up nicely
as to leaving the rust in that can cause premature wear on the rings
Old Sep 21, 2011 | 06:09 PM
Mike98Blazer's Avatar
Or if you don't have the pistons out you can pour some marvel mystery oil in there....or PB blaster....or even WD-40..... once you have the rust out you could smear a little lithium or bearing grease (use very little) on the walls to keep it from rusting again untill reassembly.
Old Sep 21, 2011 | 09:12 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
I 2nd marvel mystery oil if the engine is assembled I have used this to free up rings that rusted to the cylinder walls in salvage motors and would not turn over.
If you are rebuilding I would use a ball hone.
Old Sep 21, 2011 | 11:38 PM
xgiovannix12's Avatar
make sure you dont get that stuff on your shoes or you wont be able to stop
Just saying to make sure your safe
Chic_Bowdrie
Mar 31, 2012 08:47 AM
mbar
Nov 10, 2010 02:39 PM
mistasmiff
Detailing
Aug 30, 2006 11:57 PM
docmoody
Aug 15, 2006 10:13 AM
BlazerSquad93
Headers, Intake, & Exhaust
Mar 4, 2005 11:25 PM
