How to tell if 02 sensor bad
Old Aug 21, 2010 | 03:25 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
Default How to tell if 02 sensor bad
95 blazer 4wd 4door. how can i tell if my 02 sensors bad? what bout a fuel filter? getting less than 15mpg per gallon and i did tune up expected a fuel filter. i hear that people miles increase after changing the sensor. i dont know why in getting in the low teens. How do people get close to 20mpgs?
Old Aug 21, 2010 | 03:44 PM
cbr995's Avatar
Try changing your fuel filter.
The o2 sensor will generally throw a code. Do you have a check engine light on?
Old Aug 21, 2010 | 05:38 PM
TripleBlackBlazer's Avatar
An O2 sensor could need to be replaced without throwing a code. Sometimes they get lazy and don't report back as quickly as they used to. I'm not sure if there's an electrical test you can run on them to see how often they send out the info but that would be a good way to test it.
Old Aug 22, 2010 | 01:12 AM
helo's Avatar
helo is on a distinguished road
you can pull them out and put a torch on the tip while reading voltage on the output pins with a DMM. It should fluctuate quickly.
blazen_red_4x4
14
Jul 2, 2014 07:48 PM
Chevyblazerowner
Nov 5, 2013 08:03 PM
er0ck273
Sep 1, 2013 08:00 PM
bjasonpowell
Jan 22, 2009 12:22 PM
yzf125
Sep 17, 2005 11:45 PM
