How to tell if leaf springs are worn-out?
Old May 27, 2013 | 02:51 PM
LannyL81's Avatar
Default How to tell if leaf springs are worn-out?
I was told that if the leaf spring appears to be flat (ie no arch) then it is time to replace them.
The spring appears to be even with the ground in front of the axle, but still has an arch in the rear between the axle and rear shackle.
I was also told that the stock factory springs are rated at under 900 lbs. I see that sdtrucksprings.com has replacement springs with a 1400 lbs capacity for $128. Wonder how stiff a ride these would give?
EDIT: '02 4dr 4wd
Old May 27, 2013 | 05:07 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
Usually, my springs crack when they're worn out.
Old May 27, 2013 | 05:38 PM
chris015's Avatar
usually a flat spring means time to replace or re arch. there was a place down here that did both of mine on my dodge ram for $60. Did that last summer and so far they are good. look for rearch prices before u buy new.
Old May 27, 2013 | 06:22 PM
LannyL81's Avatar
Is the re-arching done with the springs on the vehicle?
Old May 27, 2013 | 08:34 PM
Check rear ride height, that will tell if they're sagged. Is it 2 door, 4 door, 2WD or 4WD?
Old May 27, 2013 | 09:34 PM
LeWhite's Avatar
Its my understanding that the front half of the spring does no springing, its just a trailing arm. Its the back half that deforms to make suspension compliance.
Old May 28, 2013 | 07:33 AM
LannyL81's Avatar
4dr & 4wd
check ride height?...compare left to right measurements or should there be a set distance between the top of the axle tube to the frame?
Old May 28, 2013 | 07:45 AM
chris015's Avatar
nope. you have to remove the packs and bring it to them.
Old May 28, 2013 | 06:37 PM
Rear ride height is measured from the axle bumper bracket surface down to the top of the rear axle housing. Blazer, Jimmy, Bravada spec is 5.1 to 5.8 inches. Pick ups are 5.1 to 6.4 inches.
Old Jun 1, 2013 | 07:34 PM
LannyL81's Avatar
Made the measurement and well within range; so I guess they are not worn-out....just weak. Does not take much of a load to bring the backend down....couple of 60lbs bags of concret and its 5" lower at the rear bumper; have to watch it or I will hit my head on the glass door.
Perhaps I just need to replace the springs with higher capacity ones....but concerned about the ride quality if I did this...???
kmartin
Oct 3, 2014 09:54 PM
stretch.chad
Sep 19, 2014 04:21 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
BlackOnBlack
Jun 24, 2008 11:52 PM
Blindthieves
Lifting Tech
Jul 25, 2007 01:41 AM
