so i got a bit sloppy.
Old May 31, 2013 | 11:41 AM
Kegan Hensley's Avatar
Kegan Hensley is on a distinguished road
Default so i got a bit sloppy.
My mom had asked me to find out where a gas smell was coming from. So I dropped the "skid plate" and found no visible signs of gas, next I took off the straps, dropped the tank and discovered it was a loose fuel line. Tightened it up and reassembled the blazer. Go to crank it over and nothing. Keep in mind that it was running the day prior and I didn't pull the tank because of performance issues. The pump isn't priming at all. I cranked it enough to have worked and air out of the fuel lines. So I dropped the tank again and while I'm down there I notice that the connector pins in the fuel pressure sensor have backed out of the harness. unlikely that this happens right as I'm putting it back together, I know. So I went to "rebuild" the harness as best I could to prevent the pins from walking out and I lost the order of the wires in the harness, and I've learned from experience that guess and check is not smart. So you know its a 2002 ls. If anyone can take a picture or knows for sure the order of the 3 wires so I can finish this damned truck that would be great. Thanks in advance. also I sat on google and searched the forums for about 6 hours last night
Last edited by Kegan Hensley; May 31, 2013 at 11:47 AM. Reason: yes i've searched the forums
Old May 31, 2013 | 12:02 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
halfwaydown theres a pic of the connecter
https://blazerforum.com/forum/2nd-ge...p-issue-69422/
Old May 31, 2013 | 12:20 PM
I've already swapped over to the new style. that's not the one i'm looking for. I need the 3 wire connector, not the 4 wire. but thanks for the quick reply.
Old May 31, 2013 | 03:02 PM
I think I've found what I need. I went to the JY and pulled a few tanks. I couldn't find any rear mount tanks with the same color combo that my pig tail had but I did find a side mount tank that had the same color wires. is it safe to assume that even though the tanks are mounted differently, that the wire order is the same? I wound up cutting the pig tail and taking it with me so I can splice wires if need be. i'll attach the worlds first and only picture of this harness.20130531_134659.jpg Photo by Kegan_Hensley | Photobucket
Old May 31, 2013 | 09:39 PM
bump! I need this done tomorrow morning. I have a motocross race tomorrow night and I don't want my mom driving my car while i'm gone
Old Jun 1, 2013 | 09:06 AM
does the g402 ground cause the pump not to prime if the ground it too dirty?
Old Jun 1, 2013 | 09:24 AM
okay so i screwed around with it a bit more and it turns out it was a bad connection from the g402 ground. wire brush and pump primes. long gone are the days where cars were nuts bolts fuel and spark.
Old Jun 1, 2013 | 11:14 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Ground is very important. Whenever I've done anything with fuel tanks or pumps or anything else electrical under the body I've always cleaned the grounds and made sure they were solid. Resistance is the enemy of good current flow!
Dadatone
Jul 26, 2012 12:28 PM
awesomeamerican1
Feb 12, 2012 12:29 PM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
BlazerChops
May 13, 2008 03:02 PM
timetoblaze
Engine & Internal
Oct 18, 2004 02:22 PM
