How to tell if rear axles are bad?
Old Oct 20, 2015 | 10:05 AM
ajs's Avatar
ajs
ajs is on a distinguished road
Default How to tell if rear axles are bad?
I have a 98 Blazer 4x4 and have recently had the rear seals and bearings replaced on the axle because one seal was leaking. The rear axle is leaking again from the seal. How would I tell if the axles or tubes are damaged if there is no apparent damage on the outside? The blazer rides smooth, no matter the speed.
Old Oct 20, 2015 | 03:04 PM
Rusty Nuts's Avatar
Whenever I remove the axles I take a wire brush and steel wool to the rusty part of the axle shaft where it meets the seal. This keeps that rough surface from damaging the seal. Also rub gear lube on the shaft to keep the seal from being damaged when the axle slides in. Hopefully cleaning that up will stop your leak.
Old Oct 20, 2015 | 11:34 PM
slimsummers's Avatar
slimsummers is on a distinguished road
What he said. Also examine the axles for a groove worn into them where the seals ride. If it is deep it can leak.
88s10Blazer
Jun 4, 2010 02:29 PM
tony991
Mar 9, 2010 01:08 PM
bjasonpowell
Jan 22, 2009 12:22 PM
yzf125
Sep 17, 2005 11:45 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
