HUGE FUEL PROBLEM. please help me.
Old 06-29-2010, 01:24 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
If the FPR is leaking you can smell it or see a clean spot inside the manifold where the gas has washed it clean. I don't know what year your truck is but on my 95 there's a sensor in the top of the upper intake you can pull out and shine a flashlight in and see if there's any washing. It's a lot easier than pulling the intake lol. If you hear a zapping when it's misfiring it sounds like a plug wire is grounding out or has slipped off the plug.
Old 06-30-2010, 05:03 AM
laidblazer's Avatar
laidblazer is on a distinguished road
i replaced mine it takes some time just go slow and easy. you have to take throttle body and top part of the intake off.
Old 06-30-2010, 11:04 AM
CodyJames's Avatar
CodyJames is on a distinguished road
@ laidblazer
What were your results after replacing the Fuel Pressure Reg?
I replaced my plug wires which took care of the misfiring and zapping noise. I'm still having some hesitation and sluggishness when accelerating, and the horrible fuel mileage so I guess I'll have to troubleshoot the fuel system... I did find an exhaust leak where the cat bolts on. Looks like a gasket is blown where the two pipes connect. That is probably what is throwing the P0420 codes (catalyst deficiency) I've been getting for months.
Old 06-30-2010, 12:14 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Have you replaced your catalytic converter yet? I recall from your first post that you planned on doing that. That would certainly cause hesistation and poor fuel economy.
Old 07-01-2010, 07:34 AM
CodyJames's Avatar
I haven't done it yet, but I do plan to. I'll probably look into a high flow cat-back system to add a little noise...
Old 07-01-2010, 10:45 PM
laidblazer's Avatar
i changed my cat and its getting a lil better gas milage and alot !!! but i still have the miss. i'm gonna do plugs and wires this weekend and hopefully that will be the last of my troubles.
@cody, when i replaced it, i started getting a lil better gas milage, but my biggest improvment was in my starting.no more having to stand on the gas to get it started.
mydream
06-10-2013 11:07 AM
Emsblazer72
03-24-2013 11:21 PM
sprbld417
09-28-2010 10:25 PM
joeazevedoiii
08-14-2008 08:13 PM
Jhop16
02-20-2006 10:19 PM
Quick Reply: HUGE FUEL PROBLEM. please help me.
