Hvac
Got the reservoir on order. It will be here today after 3 but ill be at work so the only chance i have will be acter 3 sunday so i will do that. I will stop by NAPA and order the check valve today. Thanks for the information. Any help here is always appericiated. Also are you saying the black hose going through the firewall turns into the grey hose under the dash. If that is the case, then i have pleanty of vacuum to the sele tor module. If so then it has been narrowed down from the selector switch out to the blend. Time to purchase a mighy vac.
Rick
Rick
I bought the reservoir and check valve (as well as much more) from rockauto.com. Very cheap compared to parts stores.
What year is your truck?
Well i managed to get it to blow from just defrost to defrost and floor. I will continue to work on it the next couple of days. If i cant get it fixed then i have to put it back together. It needs to get inspected and plated. If anything my feet wont freeze this coming winter.
Rick
Rick
twintwo34
08-19-2017 10:23 AM
Buddykitchen
07-28-2017 01:02 PM
dashyman
12-14-2005 11:28 PM
