hvac problem 99 gmc envoy
Old Dec 3, 2014 | 09:47 PM
bergz0's Avatar
bergz0 is on a distinguished road
Not sure I will check tomorrow
So unplug the vacuum assembly from the switch and hold my finger over the black line hole for 5 minutes and see if it holds vacuum? What will that prove? Thank you
Old Dec 4, 2014 | 10:58 AM
The vacuum system must be leak free to operate correctly. If the black vacuum line does not hold vacuum, it means there is a leak between the mode switch and the source, (line, reservoir, check valve). If there is a leak anywhere in the system, including actuators & lines in the dash, the air distribution system will have issues. A hand vacuum pump with a vacuum gauge is an invaluable tool for this job. It makes detecting & locating leaks much faster & easier.
swdockter
TrailBlazer GMT360/GMT370 (2002-2009) Tech
17
Mar 17, 2012 01:33 AM
Blazer_LT
Mar 13, 2012 11:44 PM
ltx400
Feb 5, 2011 12:58 AM
fiascoxl
Jan 29, 2011 09:44 PM
piedpiper27
Feb 16, 2010 12:04 AM
