i give up!!!!
Old Dec 6, 2008 | 05:55 PM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
Default i give up!!!!
i replaced my alt for the 3rd time... and i still have a voltage drop when i come to a stop or put it in gear... i have checked all my grounds and the wiring... is there thing i can possiably do???
Old Dec 6, 2008 | 07:32 PM
Blzr01Gy's Avatar
Blzr01Gy is an unknown quantity at this point
Default RE: i give up!!!!
Yea make sure your battery isn't old, no corosion on the terminals, you have proper cranking amps. I believe the alt has in internal regulator, so try these. I had the same problem with my 01 blazerso i put a duralast in it with 650 cca and it seems to be fine.
Old Dec 6, 2008 | 11:02 PM
PABlazer's Avatar
ya my battery has been tested multipul times and its cool... i think its 650 cca... the batt is 27 months old... it looks like it is brand new... ne other guess?? o and my batt is a mega-ton interstate
Old Dec 7, 2008 | 08:35 AM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
what is the RPM you are idling at? i work at autozone and i have seen many cars that get to idling to low and bring on a light, or the gauge go down, but the alternator passes the test we give it. check your idle, my 97 idles just under 600 rpm.
Old Dec 7, 2008 | 11:45 AM
WolfPack's Avatar
I dont think a 2nd thread on the subject is going to fix your problem any faster.
Old Dec 7, 2008 | 12:03 PM
rriddle3's Avatar
Please do not post more than one thread concerning the same problem. Anyone wishing to reply to this problem, please use the original thread:
https://blazerforum.com/m_187079/mpa.../tm.htm#187079
chevyguyjc87
Lifting Tech
40
Jan 4, 2010 08:18 AM
Blaize70
Nitrous, Super Chargers, & Turbos
19
Sep 20, 2008 10:23 AM
ForkliftJeff
15
Oct 4, 2007 07:46 PM
temler
Sep 3, 2007 02:57 PM
mikehillis1@yahoo.co
Engine & Internal
Oct 17, 2006 10:33 PM
