i have two problems
Old 02-19-2007, 04:23 AM
Default RE: i have two problems
If all the vacuum lines are good?? Then you could have a sticky poppet valve or leaking fuel pressure regulator, the excees gas getting into the intake makes it difficult for the computer to adjust the injectors and so it sees the truck running rich only on certain cylinders and then tries to adjust the A/F ratio from the O2sensor readings and things get mixed up causing a misfire code in the computer and rough idle...
Get the computer scanned for DTC's, if there are any then you will get closer than guessing to possibilities.
jlg822
08-13-2011 02:21 PM
The_Beast
03-27-2010 06:32 PM
CNYCountryKidd
12-06-2009 05:00 PM
whitezombie198
01-18-2009 12:58 AM
drefda
12-14-2006 01:37 PM
Quick Reply: i have two problems
