I hear roaring sound from front wheel?
Just the other week ive been hearing a roaring sound coming from the right front wheel?
Im thinking it might be a bad bearing.It sounds the loudest around 40-55mph.Please help,any ideas?
RE: I hear roaring sound from front wheel?
Definitely sounds like bearing. Also a worn idler arm or tie rod end will cause a roar if your tires are fairly aggressive. If your tires are wearing normallythen it is more than likely the wheel bearing.
Ive got bfg's AT.31x10.50.and yes my tires are wearing bad on the outside.Thanks man im gonna check that out.
put it in 4 wheel drive and see if noise stops.If it does it is the actuator switch on transfer case is bad.
F T P
23
10-03-2010 05:36 PM
jdburrell
05-30-2010 10:09 PM
