roaring sound over 45mph
Old May 19, 2015 | 03:30 PM
krzldy1949's Avatar
krzldy1949 is on a distinguished road
Default roaring sound over 45mph
Hello. 1999 Blazer, 2wd, replaced both rear axle shafts and bearings and seals; had differential fluid leaking onto brakes. Now I hear a roaring at about 45mph which gets worse with acceleration; no vibration. The one axle shaft was really worn down and there were shavings in the fluid and on the cover/magnet. I probably should have replaced the whole differential. Any comments? pointers? what's the worst that can happen if I keep driving?
Old May 19, 2015 | 09:03 PM
Assuming the noise is from the rear end, and if you had metal shavings in the fluid, it could be pinion bearings, side bearings, or ring & pinion.
Old May 20, 2015 | 02:14 PM
krzldy1949's Avatar
Thanks, can it seize up? while driving; there is no vibration at this time; what is the worst that can happen. Don't want to go back in it right now,,,
Old May 20, 2015 | 03:51 PM
Any one of those possibilities could cause it to leave you stranded. The warning sounds are there!
gatorboy44
Oct 25, 2011 04:49 PM
97Bl@zer
Dec 29, 2010 11:52 AM
F T P
23
Oct 3, 2010 05:36 PM
mav06
Nov 21, 2009 09:51 PM
backnblack99
Mar 9, 2009 08:15 PM
