IAC valve
IAC valve
I have a 1996 Blazer 4 wheel drive with a 4.3 w engine that I'm starting to a rebuild and was wondering where the location of the iac valve is. Looking down on the engine from the front I see a unit the is between the thermostat and the water pump. I think it might be it but just not sure. Also I have a unit between the battery and the coolant resvior that I have look in the Haynes manual and I can't seem to figure this one out either. Electrical connection on one end and hose on the other.
Any Help?
Thanks
Any Help?
Thanks
*Moving to 2nd Gen Tech*
What you are referring to is the EGR valve. The IAC valve is on the driver side of the throttle body towards the back.
