Idle drop when put in gear
Old Jul 9, 2013 | 09:07 PM
palmer96's Avatar
palmer96 is on a distinguished road
Angry Idle drop when put in gear
This is similar to a post i made the other day but a few things are different, please read and help.
So i did an entire tune up, plugs, wires, cap, rotor, fuel filter, air filter, trans filter, pcv. Had a 0303 code. thats gone i think it was a vacuum prob because there was a line vacuum line right above that cyl. so i put a cap on it. Now i have a 0300 code. if seems to run fine at idle but as soon as i put it in gear then it bogs down and almost dies and the CEL starts yelling at me. fuel pressure is holding strong at about 56-58.
I used autolite plugs even though i know i should have ACDelco. Could this be my problem because i have heard these engines are stubborn if ACDelco isnt used?
second issue. i pulled off the IAC and the plunger is very hard to push in and out. is this normal or does it need replaced?
Thanks in advance.
Old Jul 9, 2013 | 09:32 PM
50lb_cat's Avatar
You may have damaged the worm gear in the IAC. It does sound like the IAC valve could be contributing to your problem, is the o ring still intact?
Old Jul 9, 2013 | 09:42 PM
palmer96's Avatar
Ya i am pretty sure the o-ring was still good. I found in the Haynes manual to check for resistance across pins A and B then C and D. It should be 40-80 ohms. Is this an effective test for the IAC or is it a waste of time??
Old Jul 13, 2013 | 10:03 AM
palmer96's Avatar
IAC checked good, TPS checked good, cleaned MAF sensor.
1blazer99
Sep 27, 2009 10:55 AM
tattoo_cyrus
Lowering Tech
Oct 15, 2008 12:37 PM
Big L
Mar 14, 2008 12:25 PM
clay1937
Oct 28, 2007 10:44 AM
themckeown
Oct 22, 2007 01:11 AM
