idle shake
Old May 8, 2011 | 11:32 PM
hillwilliam2's Avatar
hillwilliam2 is on a distinguished road
Default idle shake
I have noticed a very slight shake in my truck over the last few thousand miles when it is idling. It doesn't show with any movement on the tachometer needle. Anyone have an idea of what this could be the start of? A tune up was done in December, so I think we can rule those things out.
Thank you for any thoughts you might have.
Old May 8, 2011 | 11:37 PM
rriddle3's Avatar
If you did a complete tune-up then I would look for a vacuum leak or clogged injectors (which will require a Tech2 type scanner to pinpoint).
Old May 9, 2011 | 12:13 AM
nineTnine's Avatar
nineTnine is on a distinguished road
What do you mean by a complete tune up?
Old May 9, 2011 | 06:29 AM
rriddle3's Avatar
Distributor cap and rotor, plugs, wires, fuel filter, clean the MAF sensor and EGR valve.
Old May 10, 2011 | 07:56 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Could be anything from a Tune up to Worn out motor mounts as well
Old May 10, 2011 | 09:38 PM
The tune up and motor mounts were done in December. The MAF sensor and EGR valve weren't addressed, so I'll have that checked. Thanks everyone.
92s10Blzr
Jan 8, 2010 07:58 AM
PFCBarner
Nov 21, 2009 02:03 PM
JHZR2
Jun 13, 2009 12:37 PM
blazinloud
Jan 8, 2007 03:52 PM
blazinloud
Engine & Internal
Nov 2, 2006 09:20 PM
