Ignition won't turn, wheel locked, won't shift
Old Dec 9, 2010 | 08:01 PM
shane216's Avatar
shane216 is on a distinguished road
I had the same problem on a 98 blazer, I took the whole column apart it ended up being the rod that locks the steering wheel was binding up. It wouldnt recess into the column even after i removed the lock plate i pushed it with my finger and it went right in and the key turned. I put some grease on the rod and the path it slides on and so far so good. its alot of work for something so stupid if it does it again im just taking the lock pin out and throwing it away
Old May 6, 2012 | 07:28 PM
o2plus2h's Avatar
o2plus2h is on a distinguished road
Thumbs up Thank you Thank you Thank you
Originally Posted by dennis1105
Here's what worked for me:
1. Spray dry graphite lubricant in the keyhole.
2. Aim it toward the top of the hole inside.
3. Use a pair of pliers and tap a few times on top of the the plastic housing above the key entry-way.
Bingo! The key turned smoothly!
My guess is that one or two of the (upper) top tumblers got stuck and locked up the switch. Spraying the graphite at an upward angle and then tapping on the housing was enough to get them to fall into the proper position. As a former locksmith, I can say that you probably don't need to replace the lock. The dry graphite will probably take care of the problem until it's time to junk the car.
I have been trying to figure out what the problem was with my car, 2004 Cadillac DTS, for about a week now. I feared I had to replace the ignition lock completely and read elsewhere it would be probably $400 or so to have it done somewhere.
THIS WORKED LIKE A CHARM even though it wasn't a Blazer!!! Thank you! (although I didn't have graphite but also didn't want to use WD-40 because of what other have said about the low flash point - I did, however, use PB Blaster which is supposed to have a high flash point).
You saved my hide and my wallet!
50lb_cat
Oct 3, 2017 03:40 PM
Blake726
Jan 3, 2015 07:00 PM
roaddog14
May 8, 2011 08:11 AM
fondo
Oct 25, 2009 07:07 PM
shadwell
Dec 3, 2007 01:09 PM
