Infamous P0420
I got a 96 blazer throwing a P0420 code. I recently had a full tune up (injectors cleaned new distributor cap new plugs off the top of my head) My car is a bit rough at idle. Tomorrow I am going to test the fuel pressure and for exhaust leaks.
Which o2 sensors should be checked/replaced? What else should be looked into?
I would try replacing the left upstream 02 sensor (the one before the catalytic converter) first... That most likely will be your issue. alot cheaper than the next alternative, replacing the catalytic converter. if yours is California Emissions setup like mine, then the cost is well over $1000
2dr5spdblazer
Dec 25, 2007 11:24 PM
gio17vani
Oct 27, 2007 08:43 AM
