Infamous P0420
Old Aug 25, 2014 | 09:08 PM
Cassera's Avatar
Cassera is on a distinguished road
Default Infamous P0420
I got a 96 blazer throwing a P0420 code. I recently had a full tune up (injectors cleaned new distributor cap new plugs off the top of my head) My car is a bit rough at idle. Tomorrow I am going to test the fuel pressure and for exhaust leaks.
Which o2 sensors should be checked/replaced? What else should be looked into?
Old Sep 10, 2014 | 11:34 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
I would try replacing the left upstream 02 sensor (the one before the catalytic converter) first... That most likely will be your issue. alot cheaper than the next alternative, replacing the catalytic converter. if yours is California Emissions setup like mine, then the cost is well over $1000
Old Sep 10, 2014 | 05:57 PM
chris015's Avatar
99.9999999999999999% chance is the cat....po420 is usually the cat. nothing to fix it. replace it.
Old Sep 11, 2014 | 09:34 PM
Tranzman's Avatar
Tranzman is on a distinguished road
I agree with chris015. P0420 is catalyst efficiency. the computer cannot calculate efficiency with a bad O2. so if your computer calculated efficiency, it is not working and must be replaced.
Dadatone
25
Dec 17, 2012 11:01 PM
tjmicsak
Mar 14, 2011 07:53 PM
dahondaboy
Aug 25, 2009 11:23 AM
2dr5spdblazer
Dec 25, 2007 11:24 PM
gio17vani
Oct 27, 2007 08:43 AM
