Installing Curt 13020 Hitch onto 2000 Chevy Blazer
Hello all, Do I have to drop out the spare tire to install this hitch?? I cannot seem to find the right size socket to fit the bumper bolts, any idea what size they are? Looks to be 3/4 inch socket. There is no way I can fit my large rachet and socket up into there. Should I remove the bumper support bar the is in the way? Just take off the bolt at the bottom only and slide it over so I can get my rachet in there with the socket on it. I sprayed some WD-40 on the 4 bolts. Just gotta make sure they are 3/4 inch bolts. Anyone done this before? Any problems with the installation? Thanks and any help will do.
I thought those bolts holding the bumper were 18mm,Just pop off the plastic pad on top as well(careful not to break the tabs) and I would probably remove the spare. With extensions there is no reason not to get a tool in there from my experience.The bolt up should be strait forward as well as reassembly!
I had to remove the bumper then take the 4 nuts off of the bumper brackets I do believe they were 18mm, not very easy to get at but doable. I don't have a spare tire mounted underneath, so I can't say if you should or not but an extra set of hands would be a good help.
Ok, Thanks, Don't have any 18mm sockets, will have to get some today. Would you recommend 6 sides on the socket? Do the new bolts that come with the hitch slide into the holes easily? Or do I have to clean out the holes?? Are those 4 holes threaded or not? What tool would you use to clean out the holes?? I did have my blazer sprayed with a rustoroof undercoating in 2005. The blazer is a 2000. The undercoated was the first thing I had done to it when I bought it used.
My hitch will be here tomorrow via Fedex. Will do Install when it arrives. I bought some MM socket sets, both deep and regulars for $30 at Home Depot. Should have no problems. I will leave the spare in place and work around it. Dont think it will be a problem as of now. Will see when I try to put hitch in place. I dont think I ever removed the spare since I bought the blazer 7 years ago used. The spare is still in nice usable condition. Will have to read up on how to drop the spare just in case.
I am not aware of your spare retaining mechanism,but if it is like mostne should really operate this unit at least annuallly! These are a design ready to fail! (just search this site for the nitemares) When you you need this to work it usually doesn't! I haven't carried a spare under the rear of my 97 since 2008! Cause when a rear tire failure happens off-road:the rear is on the GROUND! Good luck dropping that tire then without a HI-LO!
I got the hitch installed last night. Had to drop the spare just about 3 inches or so. Those 4 stock bolts were a pain to get out. Even with WD-40 they would not come off easily. Hitch looks nice and all bolts were torqued to specs. Put the bike rack on it, nice and sturdy. Now, all I need is a small Jon Boat or rowboat for fishing. Thanks for all the help in this one. All is good and hitch looks mean!! Did not need an extra set of hands, a plastic crate or milk crate was the perfect height for this job. Just make sure you put a rag on top of crate or else hitch will slip off. Thanks again!!
The Curt hitch that I installed on my 2001 came with bolts that were too large to fit the holes in the frame. I read a lot of complaints about Curt being a poor fit on the Xterra forum.
I installed a Reese hitch on the 2000 that I had and it was a perfect fit.
tdbone1
15
11-30-2012 06:53 PM
1996BlazerGute
08-03-2011 10:20 PM
