starter wiring access?
Old Sep 5, 2012 | 09:06 PM
spittybays
Guest
Posts: n/a
Default starter wiring access?
Greetings all. I need to track a starter wiring issue (I believe?). Is access to the solenoid connections possible through passenger wheel well? Starter is of mystery age but not original I am sure. Really believe it's a bad connection. Will start with the block ground of course. Coming of a broken foot, don't want to sound lazy but pulling the starter will mean extra pills. Thanks.............
Old Sep 5, 2012 | 09:08 PM
xgiovannix12's Avatar
yep you can access it from the wheel well.. What you can do is ...
see if you have power there with a multimeter and then go from there.
Old Sep 6, 2012 | 11:51 AM
spittybays
Guest
Posts: n/a
Seeing monsters under the bed, crappy block ground. Thanks there "BF Guru".
jdmmario
Oct 25, 2014 06:25 PM
madeforliving
Feb 16, 2008 12:59 AM
troutdude
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Nov 26, 2007 08:40 PM
MarkH
Engine & Internal
Mar 1, 2007 06:01 PM
2klt
Sep 4, 2006 07:04 AM
