Intake and head gasket replacement
Old 08-04-2012, 06:15 PM
After the intake manifold is back on the engine, you'll need to disconnect both heater hoses from the heater core, and both radiator hoses from the radiator. Flush, (blast) each hose with a garden hose until the water comes out clear. Flush in both nipples of the heater core, and flush the radiator in both directions. It's easiest just to remove the coolant reservoir to clean it out. Then reconnect all of the hoses. The auto parts stores sell cooling system flushing chemicals to clean out the remainder of the crud. Follow the directions on the bottle. Then repeat the flushing procedure to completely remove the chemical. Fill the cooling system with 50/50 Dexcool & distilled water and hope for the best.
Old 08-04-2012, 06:29 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Got it all back together. I put the RTV and manifold back on. How long should I let it set before I add coolant and fire it back up? Dry time on the RTV says 1 hour and cure in 24. Should I wait that 24 or is it good to go?
Old 08-04-2012, 06:32 PM
RTV skins over in about an hour, but I wouldn't add coolant for 24 hours.
Old 08-10-2012, 08:09 PM
Klturi421's Avatar
Last weekend I did not do my head gasket, just did my lower intake. This weekend I am going to go ahead and tackle the head gasket. As I am pulling everything off, I am beginning to wonder if the gasket can be replaced while the engine is still in the compartment?
Im guessing its possible, just a b*tch to do. Any suggestions on what I can do to make it easier?
Old 08-11-2012, 10:30 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Looks like last weekend was good practice for this weekend. You'll be re-doing the lower intake gaskets when you do the headgaskets.
Old 08-11-2012, 10:45 AM
spittybays
Guest
Posts: n/a
OMG- PLease due a hydrocarbon test before you attack those heads.
limited edition 1
01-27-2023 11:07 AM
Melrock83
07-03-2012 06:51 AM
mylittletonkatruck
03-07-2012 02:04 PM
J.R. Clay
03-17-2011 08:22 PM
01gmcjimmy
17
01-04-2008 10:17 PM
Quick Reply: Intake and head gasket replacement
