Intake seal??
Hi gang, just a couple of questions on sealing up the intake.
Seems I have an oil leak at the rear of the intake after doing the intake gaskets (dripping out from between oil pan and bellhousing). I guess I didn't apply enough sealer between the block and heads on the back.
I was re-reading D-tips install and it says to apply a bead the width of the rail and about 1" thick. Seems a bit excessive, I mean you'd have to layer it to get it that that thick no? Any thoughts?
Also, I just did this job about 3 weeks ago, can I re-use the intake gastets? Or do I require new gaskets again? TIA
Lol.....kinda what I thought. Might be a typo in his write up but I'm with you Kyle. When I did the job I applied a bead approx the width of the intake rail X about the same thickness in height (maybe 3/8"). I thought maybe I could get away with using the gaskets again due to the low torque value, and there is no more than 50 miles on it since I did the job.
What really ticks me off is the truck is running absolutley perfect....I hate to tamper with it.
boscoedoodle
16
Aug 16, 2012 04:53 PM
ComputerNerdBD
Headers, Intake, & Exhaust
Jan 5, 2012 04:53 PM
litterbug
Mar 7, 2011 09:14 PM
