interior lights wont shut off
Old Jan 11, 2007 | 10:25 PM
Melodyjn's Avatar
Melodyjn is an unknown quantity at this point
Default interior lights wont shut off
I have a 97 blazer, Just recently non of my interior lights will shut off when I shut the doors, car engine off or on. I have to pull the fuse out so the battery doesnt die.
Can anyone help?
Thanks
Old Jan 11, 2007 | 10:36 PM
Default RE: interior lights wont shut off
Probably a door switch.
Old Jan 12, 2007 | 12:10 AM
rooster's Avatar
rooster is an unknown quantity at this point
or dimmer switch, does rear stay on too. what i do is to just pull one side of the bulb out. alot easier then a fuse and kinda acts like a manuel dome switch. lol
Old Jan 12, 2007 | 12:39 AM
Chevy Lover's Avatar
Remove the door switches one at a time. When the interior lights go out, you have found the faulty switch. You probably have one shorted to ground.
Old Jan 12, 2007 | 04:55 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
ORIGINAL: Chevy Lover
This is correct. Check all the door jam switches even the one for the tail gate. If one of them is faulty (grounded constant) then your lights wont go off when everything is closed. The only other thing that would cause it is if its a 4 door and the rear door(s) are misaligned, if this happens then it does not contact the switch correctly.
Old Jan 12, 2007 | 09:24 PM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
I had this same problem with my Jimmy a couple of months ago. I was one of the door jamb switches. Took a little detective work to find the right rear switch was bad.
KingKliq1
Nov 25, 2014 11:18 AM
mjallen
Nov 5, 2014 11:24 PM
dlmallory
Feb 21, 2012 09:54 PM
chester92
Nov 14, 2011 02:50 AM
burnout350
Apr 28, 2009 01:25 AM
