intermittant starting problem (fuel pump relay)
weekend bump
2 day bump
If moving the harnesses around temporarily fixes the problem, then you either have a broken wire or an intermitten connection on one of the pins under the fuse/relay center. There is no easy way to fix this. You have to dismantle the harness back as far as it takes and inspect the wiring. If you found a bent pin, it is possible that this is your problem.
There is no such thing as a relay module. The fuse/relay center basically has traces inside that run from the connector terminals underneith to the appropriate cavities in the top where you will find either a fuse or a relay.
Now, what pin did you bend? On the underside of the fuse/relay center? How did you determine that was the appropriate pin to bend? Do you have the appropriate wiring diagram?
on the underside of the relay box there were 5 connections (or as i am calling them modules)
each of these had a 10 x 10 grid of holes that the pins from the underside of the relay box connected to.
when i first had this problem, my mechanic put a light on fuel relay wire between the fuel pump and the relay box (near the relay box) so i just looked @ the color of that wire (light brown) and then followed that wire to the connection (module)
see attached diagram (image)
i bent the curved connector (in the 'module') back-out so that it would make contact better
and then covered it w/ dielectric gel
ps - i dont know whats wrong w/ the attachment - you have to click on the image twice before it loads up so that you can see it.
it might have been grey - i just remember it was light colored - closer to white than brown (so it could have grey and i thought it was brown since i had a compact flourescent when i was looking @ it that night)
your diagram shows grey right?
(im not good @ reading circuit diagrams)
Yes, gray is the color of the wire in the F1 location, connector C3 (red) under the fuse/relay center.
I hope that bending the connector does the trick for you, but I am not sure... Once those connectors are fully seated, even tweaking the wire loom shouldn't move the connection...
Bump this up... didstraightening that bent pin fix it?
i'm having a similar intermittent problem with my '95.
3D_Illustrator
11-13-2015 01:46 PM
bludool
08-26-2009 04:01 PM
upblazer95
03-08-2009 07:15 PM
mytruck2
12-13-2006 04:50 PM
