intermittent B1036
Old Sep 21, 2010 | 04:55 PM
mfnorby's Avatar
mfnorby is on a distinguished road
Default intermittent B1036
My 98 blazer has a sir light that goes on and off intermittently. I scanned for codes and found B1036 - rt ft discriminating sensor open or shorted to voltage - I inspected the harness and connectors- all look good. The brackets on both ft sensors are kind of rusty and i know that the rt ft sensor supplies the ground for both. Has anybody had this fault? I was wondering if the ground is thru the bracket or is supplied by the harness. I think my problem is the sensor itself, can anyone tell me how to test the sensor is there a check with my ohm meter?thanks
Old Sep 27, 2010 | 09:22 AM
mfnorby's Avatar
no one? nobody here had a problem like this? well I guess I'll do my searching elsewhere
Old Mar 8, 2011 | 07:14 PM
joemech_2000's Avatar
joemech_2000 is on a distinguished road
I am having the same problem with my 1998 chevy blazer. I will report with my results
Old Mar 9, 2011 | 06:45 PM
grejef's Avatar
grejef is an unknown quantity at this point
Default Oxygen sensor
Had same code way back when replaced O2sensors has not been back
Old May 20, 2011 | 09:37 PM
Larry's98's Avatar
Larry's98 is on a distinguished road
I just asked the same question you did in Sept about B1036 code before I found your post. I cleaned the contacts on the harness to the drivers side sensor with electrical contact cleaner and my trouble cleared for a week. I have to remove the skid plate to get to the passenger side sensor connection. Will try that next.
45auto
Nov 19, 2006 10:11 PM
marks89
Nov 19, 2006 05:52 PM
greengoose89
May 16, 2006 05:06 PM
md95
Apr 14, 2006 01:49 PM
MontegoRX
Feb 15, 2006 11:30 PM
