I've got issues, PLEASE help
Old May 1, 2023 | 09:23 PM
FUN-V's Avatar
FUN-V is on a distinguished road
Default I've got issues, PLEASE help
So a little history.
I have a 2001 4-door Jimmy, just replaced the cats and the O2 sensors are reading correct on the scope, BUT it only idles fine with the MAF unplugged.
Plug the MAF in and it idles low and eventually stalls; unplug the MAF, and it runs absolutely perfect (new Delphi MAF BTW)
Anybody have any ideas or help please?
Thank you in advance.
Old May 1, 2023 | 09:45 PM
LesMyer's Avatar
What is your MAF reading at idle (and please specify idle speed)
Old May 1, 2023 | 11:42 PM
FUN-V's Avatar
Good question, I never took any.
Task for tomorrow=take MAF readings.
Old May 7, 2023 | 07:54 PM
Chevymec's Avatar
Chevymec is on a distinguished road
Is it installed the correct way? Have to ask because I have seen them installed backwards on a few vehicles.
Old Jun 5, 2023 | 01:46 PM
FUN-V's Avatar
Finally got a break in the constant rain and other projects to get the readings.
The MAFreadings are inconsistent (see pics) and now I'm getting two codes (see pic)
Old Jun 6, 2023 | 10:21 AM
LesMyer's Avatar
First MAF reading is way out low.
Second is OK
Third and Fourth are marginally low.
But better fix the O2 sensor codes before worrying about these. Diagnostic charts are attached. Whatever it is, it is affecting both O2 sensors. Check fuse 5 in Instrument panel fuse block. Also be sure to study the attachments including description, wiring diagram, and diagnostic aids. Also you can watch the O2 sensor voltage with KeyOnEngineOff and tell some things.
File Type: pdf
File Type: pdf
Old Jun 6, 2023 | 11:24 AM
FUN-V's Avatar
Second is OK
Thank you Lesmyer
Mike.308
Jan 16, 2018 07:00 PM
joejiz
May 12, 2014 05:01 PM
stinz
Feb 5, 2013 12:40 PM
lannon_j
Dec 11, 2012 02:13 PM
blkblazer
Jun 22, 2010 10:10 PM
