Just bought a Blazer and i need help
First you need to know what type of system that you have. There are three different systems in a 95. The first system, the computer is located behind the dash and is interfaced using an 12 pin OBD I assembly line data link connector. This system is completely OBD I and codes can be retrieved by jumping the pins. The second system, the computer is located behind the dash, and is interfaced with a 16 pin OBD II style Diagnostic Link Connector. This system is OBD "1.5", and requires a special scanner to retrieve the codes. The third system has the computer located on the passenger side fender, above the coolant reservoir, and uses a 16 pin OBD II style connector. This system is OBD II, and codes can be retrieved with a generic OBD II scanner. I have seen comments that these rules may not be 100% accurate for every truck.
I seem to remember some Actron scanners capable of scanning a 1.5 system but I think that they were around $300 with the connector adapter. Maybe some one here has some better info for you regarding the cheapest way to get a 1.5 system scanned as I have never had to solve this problem.
George
George
Well that's not what I was expecting to hear. I have read that those rules can be mixed up on some vehicles during that transition year. Is there an ODB certification sticker anywhere in the engine bay (ODB I vs II)? Was an engine swap ever done with that truck?
With the engine off, go to the ODB socket under the dash and measure the voltage from pin 16 to pin 4 and from 16 to 5. Watch it for a while and see if its stable.
George
George
00chevy
03-18-2013 01:58 PM
J.MCDANIEL
02-16-2012 05:57 PM
